I purchased a used Andreja (not premium) from a member over at CG and when I got the unit I noticed that the brew pressure stat was not moving above 2.3 no matter how fine or coarse I was grinding my shots. I decided to open it up and adjust the OPV and I found that the nut that you tighten or loosen for the adjustment was extremely loose almost to the point of falling off. I tightened it up and now have 9.5 bars of pressure which is good, but I also noticed with fiddling with it for several hours that the tube that connects to the OPV has 3 small leaks in it and I believe the actual nut where you make the adjustment for pressure is also leaking a tad. Here is a picture of what I am referring to:
Can I disconnect this nut all the way and add teflon tape around it to seal it or will it be a problem to completely disconnect it? Would it be possible to add a small amount of white silicon or is that not advised since this is one of the water lines?
Thanks for the help.
