by Philg on Fri Jul 23, 2010 2:46 pm
Non coffee difficulties have delayed my follow-up and it's been a long time since I did the work.
What to do is in the proceeding posts, I just wanted to say that with the help I got here, the procedure was fast and easy.
The exhaust cam pin was visibly worn but, as my wife noticed, the rubber part was also swollen - once repaired the flush was earlier and stronger, my guess is both the swelling and the wear contributed to the problem.
erics advice and photos really helped - the huge wrench I bought to remove the handle wasn't quite huge enough to remove the bottom half, I got adjustable wrenches because they were relatively cheap and locally available. The bigger one I finally got worked fine.
When I put it back together, as above, the back flush exhaust was much stronger and earlier in the lever pull - it startled me.
This was months ago, everything still working smoothly.
Thanks again!
Phil
