cyclones wrote:I'm still a little leery of this whole thing, but I've made some progress tearing the M31 down. I've realized now that I need a flare wrench set to take apart the tubing, so I went ahead and ordered a metric one (I would assume I need metric.)
Next thing I'm wanting to know is how can I check the valves to see if they work, and do I need to replace them; they're awfully expensive on cafeparts -- about $75 apiece. This machine has a bazillion of them. Or is there some way to repair the valves if they aren't working.
The electrical coils are quite heavy duty for the way they are used and usually will not fail.
The main problem will be sticking of the valve slide in the body and the build up of scale on the face of the valve seat. The ruby valve seal will almost never fail.
To clean up the valve, remove the coil by unbolting it from the side of the body, tear the valve down and descale it until everything is clean and moves freely.
Since you have not torn one of these down before have your trusty camera on hand for documentation and memory assistance. All of the valves except the 3 way by the head should be the same, but double check to be sure.
-Cecil
