cyclones wrote:Mike,
I was wrong; it turns out there is another in the assembly that is part of the inlet valve. Right next to the pump. I had to take it out today because water was not flowing through it. Weird because it had been flowing OK before descaling. Well I took the entire assembly apart and found black gunk in there. I think it is some kind of sealer. It probably turned into this gunk in response to the citric acid. Well now that it is all apart, the citric acid is taking it off. I just expect it to take several hours; maybe overnight.
<image>
Chris,
Thanks for the additional info. This is probably where my extra gicleur should go.
