The tube on the left goes to the flowmeter. The tube on the right goes to the boiler (which fills properly). The one on the far right, that's pretty much out of this picture, is incoming water.
cyclones wrote:OK, next...
I have a gasket coming for the economizer connection to the boiler,but by just snugging the screws, I was able to stop that leak (I'm still going to replace the gasket when it comes in). But I still have a very slow leak from "inside" the economizer -- around the adjustment screw. I think it's due to the little green gasket in there. That little gasket is quite stiff. Originally I wasn't going to take the economizer apart -- but it's probably good I did; there was a lot of scale in it. My original plans meant that I didn't order a gasket. I think I'll see if the people in Des Moines have one.
Also, there is no water moving when I press the brew button -- something is blocking it. I took apart the line at the flow meter and it is bone dry. No water is even going into the FM. So water must not be getting past this really complex looking setup at the back of the machine where the water comes in. I have no idea what it is called. The input line goes into it. The boiler fill/economizer line hooks to it. The line to the flow meter connects to it. I wasn't able to get that apart easily, so I decided to just leave it. It may have a blockage in it. That's the best I can think of right now. Obviously, the water can get to the economizer connection, but may not be making it back to where the flow meter line connects.
I'll go get a picture of it so you all know what I'm talking about if you don't already.
cyclones wrote:i was surprised but I got it apart and found crud inside. Citric acid seemed to work to take it off. The valve is soaking overnight because I needed to sleep.
