Questions about restoring used Cimbali Bistro-Board is working! - Page 15
Postby CRCasey on Sun Jan 24, 2010 11:53 pm
I am more than willing to say that I was wrong. And that I am glad that you have found the part that is not sending the correct voltage to the probe. Have you had any other updates?
I really want to hear the end of this story.
-Cecil
Black as the devil, hot as hell, pure as an angel, sweet as love-CMT:LMWDP#244
CRCasey
Postby cyclones on Mon Jan 25, 2010 2:32 am
I'm hoping to hear more this week. I gave him the drip tray on Friday so he can test the buttons, assuming everything else starts up OK.
I told him initially that it's not urgent so it may be another week. I assumed he'd charge me less for his time if I told him I didn't need it done right away.
If given a choice between Starbucks and espresso, I'll choose espresso every time.
cyclones
Postby cyclones on Tue Feb 02, 2010 12:48 pm
I just talked to Lee again. He thinks the electronics are all good to go. He says the pump runs, but there is a water leak. So I will get to fix that when I get it back. I am picking it up this weekend -- he lives about 30 miles away.
I've also ordered a Zassenhaus hand grinder. I'm going to see how that works. If it doesn't work well enough for espresso, I'm planning to give it to my father for use with regular coffee. I was going to try to order one from Orphan Espresso, but they never get back to me, so I finally gave up.
And I ordered a cafelat tamper and a tamping mat.
Hopefully this time next week I will be pulling my own shots on the Cimbali!
cyclones
Postby cyclones on Sun Feb 07, 2010 6:30 pm
Here's an update:
I have the machine back and it's sitting in my kitchen. Lee's repair has made the machine respond to the tank sensor like it should. I had a big leak at the pump that would spray when the pump came on, however, a little teflon tape and some snugging fixed that problem.
I also recharged my water softener with table salt per the Cimbali instructions.
At this point, it appears water is not making it to the boiler. The pump sounds a bit loud so I wonder if the path is restricted. I opened the boiler drain and nothing came out. In addition, I don't see much movement of water in the tube that comes from the tank now that the leak is fixed. So I think I have a block somewhere. I'm trying to take it apart and find the last place water reached.
Any suggestions would be appreciated. I wonder if I have a valve not opening.
Through what path does the machine fill the boiler? Is it through the hot water economizer?
cyclones
Postby cyclones on Sun Feb 07, 2010 7:32 pm
While I was checking the water lines, I decided to see if the valve to the hot water economizer was getting power. It wasn't. That had me worried that the board still wasn't working properly. I happened to notice that the steam wand valve seemed to be warm to the touch. I double checked my wires against the cimbali wiring diagram (posted earlier by Eric), and it turns out I had 8 and 9 mixed up. So I switched the wires of the steam valve and the fill valve, and hooked everything back up and turned it back on. Presto! It filled the boiler for a while and then stopped when the boiler was full.
Now I am ready to check the heating!
Yyyyaaaaaaaaaaaaaaaay!!!!!!!!
cyclones
Postby cyclones on Sun Feb 07, 2010 8:26 pm
Next update... it heats! It only took about 10 minutes and it started getting pressure in the boiler. It got up to about .8 bar and then I noticed water leaking from around the hot water economizer. I already had a new gasket coming for that. Hopefully that will fix that leak. Even after it got up to .8 bar, the vacuum breaker was still hissing a little. I don't know if that's normal or not.
I also tried to press the brew button at one point and it turned on the pump, but nothing came out. I'm wondering if this is because I have the hot water economizer screw too tight.
cyclones
Postby Paul on Sun Feb 07, 2010 8:38 pm
yay! you've come pretty far.
anti vac - no, shouldn't hiss. cimbali ones do catch a bit of water though and perhaps this boiling off is the hissing you are hearing??
econ valve - i was pretty sure that water does not pass thru this on its way to the HX (at least, it doesn't on my machine). the worst you could do is have tea water too hot or cold.
pump - did you run it long enough? hx would have been empty. hope you haven't got your pump ins and outs switched :mrgreen:
cheers
Paul
LMWDP #084
Paul
Postby cyclones on Sun Feb 07, 2010 10:55 pm
My vacuum breaker had some water bubbling out of it. But I think it wasn't completely sealing. I'll find out for sure once the economizer leak is fixed. I think that may well require the new gasket; that should be here tomorrow.
Economizer -- yes, you are right. I looked at the plumbing diagram and it doesn't go through there at all. The hot water tap water is what goes through the economizer.
Pump ins and outs are correct because the boiler filled. I had double-checked them. But you bring up a good point about the HX being empty. Perhaps I should run it again and watch the intake tube to see if water is actually moving.
cyclones
Postby Paul on Sun Feb 07, 2010 10:57 pm
water out of gr problem - also you may wish to confirm gr solenoid is working.
cheers
Paul
LMWDP #084
Paul
Postby cyclones on Mon Feb 08, 2010 2:21 am
OK, next...
I have a gasket coming for the economizer connection to the boiler,but by just snugging the screws, I was able to stop that leak (I'm still going to replace the gasket when it comes in). But I still have a very slow leak from "inside" the economizer -- around the adjustment screw. I think it's due to the little green gasket in there. That little gasket is quite stiff. Originally I wasn't going to take the economizer apart -- but it's probably good I did; there was a lot of scale in it. My original plans meant that I didn't order a gasket. I think I'll see if the people in Des Moines have one.
Also, there is no water moving when I press the brew button -- something is blocking it. I took apart the line at the flow meter and it is bone dry. No water is even going into the FM. So water must not be getting past this really complex looking setup at the back of the machine where the water comes in. I have no idea what it is called. The input line goes into it. The boiler fill/economizer line hooks to it. The line to the flow meter connects to it. I wasn't able to get that apart easily, so I decided to just leave it. It may have a blockage in it. That's the best I can think of right now. Obviously, the water can get to the economizer connection, but may not be making it back to where the flow meter line connects.
I'll go get a picture of it so you all know what I'm talking about if you don't already.
cyclones
PreviousNext
Return to Espresso Machines
