Question regarding Vivaldi timer module
Greetings!
Is there an easy way to override the Vivaldi timer module if needed? For example, if you just want to turn it off or on at a time other than the programmed cycles.
Thanks!
Thanks!
The control-panel buttons remain fully operative regardless of what cycle the timer is in. So yes, you can turn it on and off at will.
-- Richard
