by another_jim on Mon Mar 08, 2010 5:12 pm
I've had vibe pumps pulsing that sounded a little like a motor revving (i.e. a rapid one to two second cycle). There are two causes, both spring loaded valves. The first is in the OPV, the second inside the pump (a small spring and ball valve in the internal tube of the Ulka.
Removing, cleaning, and reseating the OPV will usually work. If the revving is in the Ulka itself, then reseating the small valve only works sometimes -- overheating may have deformed the little ball, and then the whole pump needs to be swapped. I'm just starting on my third pump on my Elektra (in four years). The pump runs very hot, and it seems to be prone to this problem.
