jduvivier wrote:1st line has supported this effort without complaint and have replace the Giemme controller and the pstat neither had any impact on the problem.
HB wrote:As an aside, unless it has changed in more recent models, your Isomac has a ULKA vibe pump and it needs one minute of rest for each minute running to avoid overheating.
jduvivier wrote:When I turn it on to prime the boiler the heat element "on" light comes on and the pump runs for a little over 2 minutes and then the light goes out and the pump stops running...
I forgot to mention that the green light on the power relay lights when I turn on the machine but goes off when the pump stops.
jduvivier wrote:Jim
I want to restate what I said before. You guys have been great I couldn't ask for any more help and I hope I didn't imply anything else. I am totally confounded by why it is not working so I was trying to see if anyone has had a similar problem. I now have wiring diagrams, water flow diagrams, translation of the Italian on the controller and have read a few hours worth of trouble shooting posts by others. I believe I understand how the machine runs at this point and given that I have followed all of your instructions the only other item seems like it is related to how the pump/heating elements are getting their power. I will look forward to receiving the heater and will give you a call. Thanks again.
LordFoo wrote:Are you sure that you reconnected all the wiring properly when you swapped out the controller?
