www.veniacoffee.com: purveyors of specialty coffee and exceptional equipment
Pulling shots with Lelit PL041 - Page 10
Postby 1st-line on Wed Sep 29, 2010 11:38 am
Just wanted to drop this in here:
How-to for swapping the new dispersion screen onto the older (non-QE) boiler.
http://www.1st-line.com/machines/home_m...trofit.htm
Jim Piccinich
1st-line Equipment, LLC
1st-line
Postby mini on Wed Sep 29, 2010 11:52 pm
Just ordered one today. I'll post back after I install it and and let you guys know if I notice an improvement in my shots.
matt
mini
Postby jbell on Tue Nov 16, 2010 2:01 pm
howd that dispersion screen swap work for ya?
jbell
Postby mini on Tue Nov 16, 2010 4:32 pm
It's working out really well. I would say that the new screen spreads water better, stays a tiny bit cleaner, and looks more attractive. The problems I had with the screen catching the basket rim are obviously gone. That alone might be worth the price tag, but I honestly think that it functions a little better as well. The spread of water visually seems more even. I don't know for sure if that translates into the cup, but I've yet to see a star pattern in a puck like I used to. I'd like to think it helps with channeling a bit.
Modifying the new screen to fit the old machine takes more effort than I thought it would. The combination of a slightly dull drill bit and a drill-press with a small wobble meant problems for centering the hole. You have to take out a fair amount of material and the steel is pretty tough. Make sure to go slow, pause often, and use lubrication to avoid overheating the screen. I ended up doing a lot of finishing work with a Dremel.
matt
mini
Previous
Return to Espresso Machines
