This is an S/1 manual fill, vibe pump, tank. time-to refil-the-tank light works very well - light comes on but machine keeps working.
I used CLR - CleanCaf didn't seem to do much of anything.
I re-used the 2 big o-rings (I believed the picture and only ordered 1 from CafeParts)(the flat HX gaskets were not needed here) as they were in perfect condition. I used 2 new o-rings for the 3-way solenoid where it mounts to the head.
Infinite credit goes to Owen Egan for blazing the trail! Cimbuini
before
before
before
before
after
after (the tool in the foreground is a sawed off 2.5mm allen wrench used to remove the 3-way solenoid bolts.)
after. As clean as I could get it... Maybe I wasn't patient enough...
after. You ARE admiring that nifty double needle gauge, right? A quick wipe with CLR on the brass and copper brightened it up instantly.
