Promac Club UP?
Hi All,
I recently came across this guy, and was wondering if anyone knew much about it. From what I have garnered thus far, Promac is Rancilio's "Second Brand", and this model is similar to an S26?
I have the intake in a bucket of water for now, and it takes a bit, but water comes through. I have just ordered baskets (did not come with machine), shower screen, blind filter, brush, and a new gasket since it is disintegrated/missing.
So, I plan on putting on the new screen and then backflushing. Is using a chemical solution necessary/okay on this model? I read that you cannot use chemicals for every machine.
Assuming this all works out, I will use the bucket solution for a bit until I can figure out how best to hook it up to the water supply under my sink in my kitchen.
Now, how do I get the most out of this machine? I cannot find a manual anywhere, and I am no pro barista, so I could use some guidance from anyone with this machine or a similar, and older, Rancilio.
Thanks for your time and input!
Sincerely,
Ben
- erics
- Supporter ★
You can download manuals for similar machines here: http://www.rancilio.com/rancilio/index. ... language=3
I would do a little disassembly and take some pics to post. In addition, some amazing things can happen when your location is a little more specific than "United States".
Ok, updated my location! I will take some more pics. I got the manual for the S20 series, but there are some marked differences with this guy from what I can tell.
- HB
- Admin
Since you're in Durham... Friday mornings at Counter Culture Coffee in Durham, NC.
^ Thanks, my friend Jonathan works there, and Mark (Big Spoon Roasters) used to work there. I run This & That Jam http://www.thisandthatjam.com and so I am going to try and make it over there on Friday morning, sad to say I have not since moving to the triangle a year ago, but I have a 9-month old, so, I figure that is an excuse.
Ok, here are some photos of the inside. Do things look alright to you all? I got a 3-cup portafilter basket and it was too deep for these portafilters, so waiting on the new 2-cup one still. Is this the correct valve on the end of the water intake so that I can use a bucket for water, at least as an interim solution? Break valve I believe?
Any input is greatly appreciated! I plan on backflushing the machine a few times, and I am waiting on a new screen. Should I use chemicals for the backflush? I read that some machines cannot take that due to aluminum parts internally and to just use water.
Any and all help is greatly appreciated!
Sincerely,
Ben
- erics
- Supporter ★
Seeing as though your boiler pressure is about 1.0 bar higher than what it should be , I would travel to that Friday morning "get together" that Dan mentioned NOW. There is a lot of intelligence that gathers there.
Your maximum boiler pressure should be around 0.9 bar and I would attend to that before anything else. Yes, you can use Cafiza or Joe-Glo for backflashing on your machine.
