I am the new owner of a used Elektra T1 (from 2000) that has a few issues. I've attached pictures of the problems below. I'd appreciate any advice from fellow Elektra owners or anybody if possible!
1.) The steaming wand drips water slowly as the boiler pressure goes up. I've tried tightening the two mutual nuts holding the steaming handle in place to no avail. Do I need to replace some gasket or o-ring?
2.) The pump pressure gauge doesn't work! I am able to run water through the machine and brew shots, but I'm not sure what is wrong with this gauge though!
3.) I don't think the boiler is autofilling for some reason. After a little while, I am unable to pull any water from the hot water arm...only steam/hot air comes out.
4.) The highlighted section in the 1st picture is leaking a little bit of water as well.
