Problem with drooping E61 brew lever
Link to "Problem with drooping E61 brew lever"by ronron on Thu Jan 07, 2010 4:51 pm
Dear fellows
I will appreciate your help with a problem I have with my Cellini espresso machine unit,
When I start lifting the group handle to start the water flow, if there is no pressure the handle will stay up and water will flow, if the machine is ready for use and there is pressure in the barrel the handle will move slightly down and the water flow will stop. The result is that I need to hold the handle during all the process.
Any idea what is the problem?
Appreciate your help
Best regards
Ron
ronron
Link to "Problem with drooping E61 brew lever"by cafeIKE on Thu Jan 07, 2010 9:24 pm
Does the pump continue to run?
If not, the switch cam needs adjustment.
If so, sounds like internal wear in the group.
cafeIKE
Link to "Problem with drooping E61 brew lever"by ronron on Fri Jan 08, 2010 6:23 am
1. When it's happens the pump stops (the handled is not reaching the switch).
2. Regarding the switch cam adjustment, the two screws adjusting the switch position on the machine body is on the top end of its position toward the group handle. If it will change to longer switch screw it will probably give the effect of continues pumping but since the machine is under warranty if the problem is in the group I want to fix the core problem and not temporary cheap and simple solution as switch screw replacement that live me with future bigger problem in the group.
3. Regarding group wear, which part is probably causing the problem?
Ron
ronron
Link to "Problem with drooping E61 brew lever"by CSME9 on Fri Jan 08, 2010 9:12 am
My lever when pushed down (off) would bounce back and not release all the pressure. Turned out the flathead screw on the outside of the cam/lever was loose.
WS
CSME9
Link to "Problem with drooping E61 brew lever"by cafeIKE on Fri Jan 08, 2010 9:11 pm
The pump switch engagement is controlled by the switch mounting boss lock nuts
If the cam is tight on the shaft and if the switch is out as far as it can go, then the switch is probably defective.
cafeIKE
Link to "Problem with drooping E61 brew lever"by ronron on Sat Jan 09, 2010 4:47 pm
Is the lever should stay up and not move during the coffee flow or is it ok that it moves slightly down?
Since if it is not ok the problem probably inside the group but if it's ok the problem is probably with the switch.
ronron
Link to "Problem with drooping E61 brew lever"by erics on Sat Jan 09, 2010 5:59 pm
Everything Ian has advised is correct but you may very well have two problems. The lever moves through a ninety degree angle from all off to all on. A TYPICAL value for the clearance between the lever's cam and the switch when the lever is down is ~ 0.048" = ~ 1.2 mm.
When you lift the lever to brew, it should stay in that position. A diagram from you might be helpful because it is hard to interpret "moves slightly down". As you say the machine is under warranty, here's hoping that the dealer you made the purchase from is in Moscow - I'd make a phone call.
erics
Link to "Problem with drooping E61 brew lever"by cafeIKE on Sat Jan 09, 2010 10:06 pm
ronron wrote:Is the lever should stay up and not move during the coffee flow or is it ok that it moves slightly down?
I don't know about the Cellini, but both my Vibiemme levers do not move at all from the full up position during a shot.
cafeIKE
Link to "Problem with drooping E61 brew lever"by HB on Sat Jan 09, 2010 10:47 pm
erics wrote:A diagram from you might be helpful because it is hard to interpret "moves slightly down".
The diagram of the E61 parts in the brew position may be helpful:
From Is there a purpose for the E61 middle brew lever position?
When the lever is in the brew position, allowing water to enter the chamber, the leading lobe of the cam shown above is just past the stem that lifts the upper valve. That is, the cam/spring-loaded stem naturally act as a detent. It should not take much resistance to hold the lever in the upper detent position, since it's already held fairly snug in its travel by the sealing O-rings for the cam shaft connected to the lever itself.
Ron didn't mention the age of this machine, but a worn upper stem (#16), worn cam (#6), or weakening upper valve closure spring (#18) could result in less staying power for the lever. E61 Group Espresso Machine: Detailed Interior Schematics and the original E61 patent diagram will make these parts references clearer:
From The E61 Group - Truth and Lies
Coffeetime's How to Lubricate Your E61 Group includes some nice photos and notes a common sign of valve lifter wear is that the lever sometimes drops down on its own when pulling a shot.
Return to Espresso Machines
