Hi,
Have had my silvia for a few days now with few problems, pulled several standard shots with it, nothing out of the ordinary. However, recently and very suddenly it has started having problems with extraction - I literally, made one good shot, then 30 minutes later when I was making another, the extraction rate went down to next to nothing.
The shot dribbles out very slowly (if at all), and only after ~10 seconds or so. Even when running for up to a minute, I only end up with a very small amount. The steam wand seems fine - it seems to produce hot/flowing water and steam adequately, without delay.
Tried doing a thermometer reset - no luck. Also tried the coffee+water buttons 4-cup flush.
Perhaps this is a portafilter issue? Or something to do with pressure? The gasket?
Two things that may be relevant: its a 9-month old second hand machine, so may not have been descaled recently (but surely this wouldnt affect the extraction to this degree?). Also, I found a thin metallic ring with 3 flat edges amongst the packaging. It looks like it may fit in the portafilter or gasket - any ideas?
I've done a lot of research around the forum for similar problems, but haven't found anything so far, any help would be greatly appreciated.
