Narwal wrote:Hi Folks,
seems that there are people abroad with similar problems. I came along your forum by a Google search because back home in Germany apparently nobody was competent to give an answer to my problem. Maybe one of you experienced Junior Users could help?
I only recently ordered a brand new La Cimbali Junior 21 S (with water tank, no tap connector, manufactured in May 2005).
Now that I had set up the machine I found that the pressure gauge suggests an apparently strange pressure behaviour:
First, when being switched on the machine heats up and pressure rises to a max. of approx. 1,1bar. Than the pressure slowly declines to as low as 0,65 bar. Then it starts heating up again, reaching about 1,1bar again. Afterwards the whole cycle starts all over again.
Is such a deadband considered to be acceptable? My local dealer here in Germany tried to convince me that this was totally normal. My request directly at LaCimbali Italy remained unanswered (maybe they don't speak English, unfortunately I don't speak Italian either).
So maybe one of you could tell me what to do now. That would be great.
Thanks a lot and Greetings from "Old Europe"
(Please excuse my English, It's been a while that I practiced it)
Narwal
If your dealer really believes that a normal pressurestat deadband is 1.1-0.65=0.45 bar, then I think you should find a new dealer. This is an ENORMOUS (HUGE) temperature variation in the boiler of a heat exchanger machine and is wholly UNACCEPTABLE. This will DEFINITELY degrade the quality of the espresso you produce, and no one should spend as much money as you spent on your new machine just to get bad espresso.
I own two Cimbali Juniors; a 9 year old pourover (tank) vibratory pump version and a 2.5 year old rotary pump version that is plumbed in to the household water supply. The older machine has a Sirai pressurestat in it, and when this type of pressurestat is new or has a new membrane in it, you can expect a deadband of 0.15 bar, 1/3 of the deadband you are experiencing. It is silly to believe that a newer microswitched pstat should have a greater deadband than an old style Sirai; in fact, there are now "low deadband" microswitched pstats made by CEME that have adjustable deadbands down to 0.08bar.
The Cimbali OEM microswitched pstat in your machine is the same one as in my rotary machine. In my opinion, these are not very well designed nor executed. The problem is in the machining and assembly of the mechanical "lever-like" portion, not the microswitch itself. I would not be surprised that if you played around with the mechanical parts, seeing if they rub or catch anywhere, that maybe you can fix this problem without replacing the pstat. Another possible problem is the location of the pstat; at least on my rotary machine, it is at the very back which means you need to take off the side panels and the back panel just to access it. The lever like parts if oriented incorrectly can rub on the case itself and this can cause the problems you are observing. Mine had to be replaced and when I put in the new one I intentionally turned it around backwards so that the mechanical parts can't rub on the case back.
If you can't fix this yourself by playing with the lever like parts, tell your dealer in no uncertain terms that he must replace this part; it is defective. When the warranty has run out, you can replace the Cimbali pstat with the CEME low deadband pstat, or you can PID your machine, which is what I did to my rotary machine. I am in the process of replacing the Sirai in my old vibe machine with a low deadband CEME wired through a relay. You won't need to put a relay in the newer machine since I believe it already has one in the undertray electronics area.
Good luck.
ken
