mauricem wrote:Hi Ken,
looking forward to your results on this one, I have a couple of juniors with Sirai pstats and would like to tighten the deadbands if possible.
BTW I understand the screw adjustment raises or lowers the boiler off point but is the boiler on point also adjustable, if not what determines it?
One of my machines turns back on at .9 and the newer (my 2000) drops down to .8 before cutting in. I thought Id wait to see your results with the CEME before replacing the membrane.
cheers
Maurice
Hi Maurice,
The deadband is not adjustable on the Sirai, only the overall range, the width of which is probably never much better than 0.15 bar, and which is best with a new membrane and worst with an old calcified or stiffened one. When the total deadband (high minus low value) reaches close to 0.2bar, it is time to replace the membrane or the whole stat, depending on which version you have. So, when you turn the adjusting screw the entire range, the deadband, shifts either up or down based on which direction the screw is turned.
I have today done some basic Scace Thermofilter thermometry on my vibe Junior, with the old Sirai in place. I am going to just paste in the post I made on a.c. about this as I don't want to retype it. In the next few days I'm going to swap out the Sirai and replace it with the low deadband CEME pstat, and this data I'm pasting in here will serve as a baseline for comparison. If anyone has any suggestions for what else I might test with the Scace device before I swap pstats, please respond immediately because once I put the new pstat in, I intend to leave it in place barring some sort of unanticipated problems. Herewith what I posted earlier today on a.c.:
(please note that all thermography data is reported in degrees Fahrenheit; I think this gives more precision since degrees are reported by the Fluke digital thermometer in precision of tenths of a degree, and a tenth of a degree F is less than a tenth of a degree C !!!!!!!!!!!!)
Hi,
Since I inadvertently posted most of this data an hour ago, I'm going to add
the repeat of the last, 6 shot test at the end and just post it now. I have
not had time to look this over, and in any event, it is what it is, raw
data. What is presented is second by second shot temperature measurements
using my new Scace Thermofilter device (sold by EPNW) along with a Fluke
54II datalogger. Each series of shots was separated by at least 1 hour from
subsequent shot series. In most series there was a flush, and the PF was
removed for the measured flush then reinserted in approximately 10 seconds
and measurement began. The Thermofilter was not removed in between shots.
All series except the last one (and its repeat) had 60 seconds in between
shots; the last series, as noted, had 90 seconds and this was done with a
higher pstat setting (1.10bar to 1.25 bar). The earlier series of tests
were done with a pstat setting of 1.0 to 1.15 bar, showing a deadband of
0.15 bar on the Sirai pstat, which has a nearly new membrane in it.
I've decided to start a new thread on this because all of my posts on this
could be a bit confusing since they have much of the same data. So here it
is laid out, unadulterated Scace Thermofilter data on a 9 year old
unmodified Cimbali Jr. S Pourover, with thermography obtained as described.
To me, the interesting part will be to compare this, with what I can get
after installing the low deadband pstat later on in the week. Then we can
see how much impact reduced boiler temperature hysteresis has, with
comparison to these measurements, in a setup that is much easier to
accomplish than installing a PID. We will hopefully see if there is a less
invasive way to improve temperature control on a commercial 1 group Hex
machine without having to do more than swap out a pstat. If you have any
suggestions for must do baseline testing before I swap the pstats, please
let me know; I think the surgery will be done in the next couple of days
when I have time, after which a low deadband CEME pstat will reside where
the Sirai now lives.
I hope the additional data contained in this post will address questions
raised by a
number of you about different issues. I'm going to try to post the data in
a way that it can be compared, heaven help me. I will leave in the earlier
data and paste in new data:
> TEST SERIES #1, with 130ml Flush pre test, Shot #1:
> 186.1F 188.3F 190.6F (WBC would start recording here) 196.3F 197.9F
> 198.1F 197.9F 197.3F 196.9F 196.5F 196.2F 195.9F 195.7F 195.6F 195.4F
> 195.3F 195.1F 195.1F 194.9F 194.7F 194.5F 194.5F 194.3F 193.7F 193.4F (end
> of first shot)
> TEST SERIES #1, with 130ml Flush pre test, Shot #2:
> 189.1F 189.3F 190.5F (WBC would start recording here) 193.5F 195.1F 195.3F
> 195.5F 195.3F 194.9F 194.7F 194.5F 194.3F 194.2F 194.1F 194.0F 193.9F
> 193.8F 193.8F 193.7F 193.7F 193.7F 193.7F 193.6F 193.5F 193.4F 193.3F
> 193.3F 193.2F 193.1F 193.0F 192.9F 192.8F 192.2F
> TEST SERIES #1, with 130ml Flush pre test, Shot #3:
> 186.8F 187.4F 189.5F (WBC would start recording here) 192.3F 193.2F 194.1F
> 194.1F 193.9F 193.7F 193.5F 193.3F 193.3F 193.2F 193.1F 193.1F 193.1F
> 193.1F 193.1F 193.1F 193.1F 193.1F 193.1F 193.1F 193.1F 193.1F 193.1F
> 193.1F 193.1F 193.1F 193.0F
Here is a repeat of the TEST SERIES #1, with 130ml Flush pre test, for
evaluation of consistency:
TEST SERIES #1, REPEATED, with 130ml Flush pre test, Shot #1
183.7F184.9F 191.5F (WBC would start recording here) 192.2F 195.5F 199.3F
200.0F 200.1F 199.9F 199.3F 199.0F 198.7F 198.1F 197.8F 197.7F 197.5F 197.3F
197.2F 197.1F 197.0F 196.9F 196.8F 196.7F 196.6F 196.5F 196.4F 196.3F 196.1F
196.0F 195.9F
TEST SERIES #1, REPEATED, with 130ml Flush pre test, Shot #2
191.3F 191.4F 192.7F (WBC would start recording here) 195.7F 197.0F 197.1F
197.0F 196.6F 196.2F 195.8F 195.5F 195.3F 195.1F 195.1F 195.1F 195.0F 194.9F
194.9F 194.8F 194.8F 194.7F 194.7F 194.7F 194.6F 194.6F 194.6F 194.5F 194.5F
194.5F 194.5F
TEST SERIES #1, REPEATED, with 130ml Flush pre test, Shot #3
189.7F 190.3F 191.0F (WBC would start recording here) 194.3F 196.1F 196.7F
196.5F 196.1F 195.7F 195.5F 195.2F 195.0F 194.9F 194.7F 194.7F 194.6F 194.6F
194.6F 194.5F 194.6F 194.5F 194.5F 194.6F 194.6F 194.5F 194.5F 194.5F 194.5F
194.5F 194.4F
> TEST SERIES #2, WITHOUT ANY COOLING FLUSH, Shot #1:
> 185.1F 201.2 204.7 (WBC would start recording here) 206.5 207.2F 206.5
> 205.9 205.2F 204.5 203.8 203.6F 203.3F 203.2F 203.2F 203.2F 203.1F 203.1F
> 203.1F 203.0F 203.0F 202.9F 202.9F 202.7F 202.7F 202.7F 202.6F 202.5F
> 202.4F 202.3F 202.2F
> TEST SERIES #2, WITHOUT ANY COOLING FLUSH, Shot #2:
> 194.7F 200.0F 201.2F (WBC would start recording here) 203.5F 204.1F 203.9F
> 202.9F 202.3F 202.0F 201.3F 201.1F 200.9F 200.7F 200.5F 200.3F 200.2F
> 200.1F 200.0F 199.9F 199.8F 199.7F 199.7F 199.6F 199.5F 199.4F 199.3F
> 199.3F 199.2F 199.1F 199.1F
> TEST SERIES #2, WITHOUT ANY COOLING FLUSH, Shot #3
> 193.9F 194.4F 196.6F (WBC would start recording here) 198.9F 200.7F 201.1F
> 200.9F 200.3F 199.6F 199.1F 198.6F 198.4F 198.1F 197.9F 197.8F 197.7F
> 197.5F 197.5F 197.4F 197.3F 197.3F 197.3F 197.1F 197.1F 197.0F 196.9F
> 196.9F 196.7F 196.7F 196.5F
I have not repeated the non-flush tests
> After seeing these results I decided to repeat the flush test with a 150ml
> flush rather than my previous standard 130ml flush
> TEST SERIES #3, with 150ml Flush pre test, Shot #1:
> 176.3F 180.7F 190.7F (WBC would start recording here) 193.6F 194.6F 194.8F
> 194.7F 194.3F 193.8F 193.5F 193.3F 192.9F 192.7F 192.5F 192.3F 192.1F
> 191.9F 191.7F 191.5F 191.3F 191.2F 191.0F 190.9F 190.7F 190.5F 190.3F
> 190.2F 190.0F 189.9F 189.8F
> TEST SERIES #3, with 150ml Flush pre test, Shot #2:
> 182.1F 186.2F 188.8F (WBC would start recording here) 191.2F 191.7F 191.6F
> 190.9F 190.3F 189.9F 189.5F 189.3F 189.2F 189.1F 189.1F 189.1F 189.1F
> 189.1F 189.0F 189.0F 189.0F 188.9F 188.9F 188.9F 189.0F 189.0F 188.9F
> 188.9F 188.9F 188.9F 188.9F
> TEST SERIES #3, with 150ml Flush pre test, Shot #3:
> 183.5F 187.3F 189.0F (WBC would start recording here) 189.6F 189.7F 189.6F
> 189.5F 189.4F 189.3F 189.3F 189.3F 189.3F 189.4F 189.4F 189.5F 189.5F
> 189.5F 189.6F 189.7F 189.7F 189.8F 189.9F 189.9F 189.9F 189.9F 189.9F
> 189.8F 189.8F 189.7F 189.7F
This was not repeated
OK, now for some new data:
TEST SERIES #4, with 140ml Flush pre test, Shot #1:
180.06F 181.1F 192.1F (WBC would start recording here) 193.9 196.1F 197.3F
197.4F 197.3F 197.0F 196.3F 195.7F 195.5F 195.1F 194.8F 194.5F 194.4F 194.2F
194.1F 193.9F 193.7F 193.7F 193.5F 193.5F 193.3F 193.3F 193.1F 193.0F 192.9F
192.8F 192.7F
TEST SERIES #4, with 140ml Flush pre test, Shot #2
186.1F 190.7F 193.1F (WBC would start recording here) 195.4F 196.0F 196.0F
195.3F 194.6F 194.3F 193.9F 193.5F 193.3F 193.1F 193.0F 192.9F 192.9F 192.8F
192.7F 192.7F 192.7F 192.7F 192.7F 192.7F 192.7F 192.7F 192.7F 192.6F 192.6F
192.5F 192.5F
TEST SERIES #4, with 140ml Flush pre test, Shot #3
187.3F 190.5F 192.7F (WBC would start recording here) 195.1F 195.8F 196.0F
195.8F 195.1F 194.9F 194.6F 194.3F 194.1F 193.9F 193.7F 193.6F 193.5F 193.5F
193.5F 193.4F 193.4F 193.3F 193.4F 193.4F 193.4F 193.4F 193.3F 193.3F 193.3F
193.3F 193.3F
After more than an hour in between, this test was repeated:
TEST SERIES #4, REPEATED, with 140ml Flush pre test, Shot #1
179.9F 191.2F 194.9F (WBC would start recording here) 195.5F 197.8F 199.6F
199.8F 199.6F 198.5F 197.9F 197.3F 197.0F 196.7F 196.4F 196.2F 196.0F 195.8F
195.7F 195.6F 195.5F 195.3F 195.2F 195.1F 194.9F 194.9F 194.8F 194.7F 194.5F
194.5F 194.3F
TEST SERIES #4, REPEATED, with 140ml Flush pre test, Shot #2
188.9F 190.0F 193.1F (WBC would start recording here) 194.2F 194.5F 194.4F
194.1F 193.9F 193.7F 193.6F 193.5F 193.5F 193.5F 193.5F 193.4F 193.4F 193.4F
193.5F 193.5F 193.5F 193.5F 193.5F 193.5F 193.5F 193.5F 193.5F 193.5F 193.5F
193.5F 193.5F
TEST SERIES #4, REPEATED, with 140ml Flush pre test, Shot #3
188.6F 189.2F 191.6F (WBC would start recording here) 195.1F 195.8F 195.9F
195.7F 195.0F 194.7F 194.4F 194.1F 194.0F 193.8F 193.8F 193.8F 193.9F 193.8F
193.8F 193.7F 193.7F 193.7F 193.7F 193.7F 193.7F 193.8F 193.8F 193.7F 193.7F
193.6F 193.5F
TEST SERIES #5, with 100ml Flush pre test, Shot #1
180.9F 186.0F 189.6F (WBC starts recording here) 193.7F 196.7F 199.1F 199.9F
200.1F 200.1F 199.9F 199.5F 199.2F 198.8F 198.5F 198.3F 198.1F 197.9F 197.8F
197.7F 197.6F 197.5F 197.4F 197.3F 197.2F 197.1F 196.9F 196.8F 196.7F 196.6F
196.4F
TEST SERIES #5, with 100ml Flush pre test, Shot #2
191.5F 191.5F 192.2F (WBC starts recording here) 194.5F 196.2F 197.5F 197.5F
197.4F 197.0F 196.6F 196.2F 195.9F 195.7F 195.6F 195.5F 195.5F 195.4F 195.4F
195.3F 195.3F 195.2F 195.2F 195.1F 195.0F 194.9F 194.9F 194.9F 194.8F 194.7F
194.7F
TEST SERIES #5, with 100ml Flush pre test, Shot #3
189.9F 190.5F 191.2F (WBC starts recording here) 193.7F 195.3F 196.3F 196.5F
196.3F 196.1F 195.7F 195.5F 195.3F 195.1F 194.9F 194.8F 194.7F 194.7F 194.6F
194.5F 194.5F 194.5F 194.5F 194.5F 194.4F 194.4F 194.4F 194.3F 194.3F 194.3F
194.2F
TEST SERIES #5, REPEATED, with 100ml Flush pre test, Shot #1
179.5F 183.2F 190.9F (WBC starts recording here) 191.8F 196.3F 199.6F 200.0F
200.1F 200.1F 199.7F 199.5F 199.1F 198.9F 198.6F 198.4F 198.2F 198.1F 197.9F
197.8F 197.7F 197.5F 197.5F 197.4F 197.3F 197.2F 197.1F 197.1F 196.9F 196.8F
196.7F
TEST SERIES #5, REPEATED, with 100ml Flush pre test, Shot #2
191.5F 191.5F 192.7F (WBC starts recording here) 194.8F 197.1F 197.7F 197.9F
197.6F 197.3F 196.7F 196.5F 196.2F 196.0F 195.9F 195.8F 195.7F 195.7F 195.6F
195.5F 195.5F 195.4F 195.3F 195.3F 195.3F 195.1F 195.1F 195.1F 195.1F 194.9F
194.9
TEST SERIES #5, REPEATED, with 100ml Flush pre test, Shot #3
189.3F 190.0F 193.1F (WBC starts recording here) 195.5F 197.1F 197.4F 197.5F
197.1F 196.5F 196.1F 195.7F 195.5F 195.2F 195.1F 194.9F 194.9F 194.8F 194.7F
194.6F 194.5F 194.5F 194.5F 194.5F 194.5F 194.5F 194.5F 194.5F 194.4F 194.4F
194.4F
Then I bumped up the pstat as far as I could comfortably go on the 9 year
old Sirai (with nearly new pstat membrane) to cycling between 1.10 and 1.25
bar; beyond that I am afraid I'll tear the thing off it's mounting, the way
it is acting! I also did two things suggested by Jim Schulman; I increased
the intershot interval to 90 seconds, and also ran a total of 6 shots rather
than 3.
TEST SERIES #6, with higher pstat setting and with 130ml Flush pre test,
Shot #1
185.4F 192.8F 195.7F (WBC starts recording here) 197.5F 199.1F 201.5F 202.1F
202.1F 201.9F 201.3F 200.7F 200.1F 199.7F 199.4F 199.1F 198.9F 198.7F 198.5F
198.3F 198.1F 198.1F 197.9F 197.7F 197.6F 197.5F 197.5F 197.3F 197.3F 197.2F
197.1F
Shot #2
190.1F 190.1F 194.4F (WBC starts recording here) 197.3F 200.1F 200.9F 201.0F
200.7F 200.0F 199.3F 198.9F 198.6F 198.3F 198.2F 198.1F 198.1F 198.0F 198.0F
197.9F 197.9F 198.0F 197.9F 197.9F 197.9F 197.9F 197.9F 197.9F 197.9F 197.8F
197.8F
Shot #3
190.9F 190.9F 192.8F (WBC starts recording here) 196.5F 199.3F 199.9F 199.9F
199.2F 198.9F 198.5F 198.3F 198.2F 198.1F 198.1F 198.1F 198.1F 198.2F 198.2F
198.3F 198.3F 198.3F 198.3F 198.3F 198.3F 198.3F 198.3F 198.2F 198.2F 198.1F
198.1F
Shot #4
190.3F 190.3F 194.7F (WBC starts recording here) 197.2F 199.6F 200.6F 200.7F
200.6F 200.2F 199.7F 199.3F 199.1F 198.9F 198.8F 198.7F 198.7F 198.7F 198.7F
198.8F 198.7F 198.7F 198.7F 198.7F 198.7F 198.7F 198.7F 198.7F 198.7F 198.7F
198.6F
Shot #5
189.1F 191.8F 197.3F (WBC starts recording here) 200.1F 202.4F 203.0F 202.8F
201.7F 201.1F 200.5F 200.1F 199.9F 199.6F 199.4F 199.3F 199.2F 199.1F 199.1F
199.2F 199.2F 199.1F 199.1F 199.1F 199.1F 199.1F 199.1F 199.1F 199.1F 199.0F
199.0F
Shot #6
189.4F 193.9F 199.5F (WBC starts recording here) 201.3F 203.4F 203.5F 202.9F
202.2F 201.6F 200.9F 200.7F 200.4F 200.1F 199.9F 199.8F 199.7F 199.6F 199.5F
199.5F 199.4F 199.4F 199.4F 199.4F 199.3F 199.3F 199.3F 199.4F 199.4F 199.4F
199.4F 199.4F
TEST SERIES #6, REPEATED, 90 seconds in between shots, with higher pstat
setting and 130ml Flush pre test, shot #1
176.1F 190.6F 193.7F (WBC starts recording here) 194.9F 198.9F 200.5F 201.1F
201.1F 200.9F 200.5F 200.1F 199.7F 199.4F 199.1F 198.9F 198.7F 198.6F 198.5F
198.3F 198.2F 198.1F 197.9F 197.8F
197.7F 197.6F 197.5F 197.4F 197.3F 197.3F 197.1F
TEST SERIES #6, REPEATED, with higher pstat setting and 130ml Flush pre
test, shot #2
191.9F 192.0F 194.5F (WBC starts recording here) 196.7F 198.8F 199.4F 199.5F
199.3F 198.6F 198.3F 197.9F 197.5F 197.3F 197.1F 197.1F 197.0F 196.9F 196.9F
196.9F 196.9F 196.9F 196.9F 196.9F 197.0F 197.0F 197.0F 197.0F 196.9F 196.9F
196.9F
test, shot #3
188.9F 190.3F 197.7F (WBC starts recording here) 199.9F 201.8F 201.9F 201.1F
200.5F 199.9F 199.3F 198.8F 198.5F 198.3F 198.1F 198.0F 197.9F 197.9F 197.9F
197.8F 197.7F 197.7F 197.7F 197.7F 197.6F 197.5F 197.5F 197.5F 197.5F 197.5F
197.5F
test, shot #4
188.3F 195.1F 197.3F (WBC starts recording here) 199.7F 201.9F 202.0F 201.8F
200.7F 200.1F 199.7F 199.1F 198.9F 198.7F 198.7F 198.6F 198.5F 198.5F 198.4F
198.3F 198.3F 198.3F 198.3F 198.3F 198.3F 198.3F 198.2F 198.2F 198.2F 198.2F
198.1F
test, shot #5
188.9F 193.9F 198.7F 200.7F 202.9F 203.3F 202.6F 201.6F 200.9F 200.2F 199.7F
199.4F 199.2F 199.1F 199.0F 198.9F 198.9F 198.9F 198.8F 198.8F 198.8F 198.8F
198.8F 198.8F 198.7F 198.7F 198.7F 198.6F 198.6F 198.6F 198.5F 198.5F 198.4F
test, shot #6
188.9F 190.6F 199.4F 201.1F 203.4F 203.6F 203.3F 202.2F 201.3F 200.6F 200.3F
200.0F 199.8F 199.7F 199.5F 199.4F 199.3F 199.3F 199.3F 199.3F 199.3F 199.2F
199.2F 199.2F 199.1F 199.1F 199.1F 199.0F 198.9F 198.9F 198.9F 198.8F 198.7F
OK, that is it for now!
ken
