Pressurestat for a Bezzera BZ99?
Postby beanmuncher on Mon Nov 15, 2010 12:33 pm
I've had my Bezzera BZ99 for a bit over three years and I've occasionally had problems with it dumping copious quantities of steam (not out the brewhead - through the release valve on the boiler). This is not a regular issue, but it is exceedingly disconcerting when it occurs. A quick bit of googling and forum searching this morning suggests to me that my pressurestat (which is probably original to the machine, which in turn was built in '96) needs to be replaced - is this the right idea? If so, what part am I looking for (I'd rather not order the wrong one - especially this week).
beanmuncher
Postby hperry on Mon Nov 15, 2010 2:47 pm
Wonder if the relief valve itself could be the culprit?
Hal Perry
hperry
Postby beanmuncher on Mon Nov 15, 2010 6:47 pm
Might be - I've pulled it before, and nothing has seemed particularly wrong with it. Any way to tell if it needs to be replaced?
beanmuncher
Postby HB on Mon Nov 15, 2010 7:23 pm
beanmuncher wrote:I've had my Bezzera BZ99 for a bit over three years and I've occasionally had problems with it dumping copious quantities of steam (not out the brewhead - through the release valve on the boiler).
Yep, it is the pressurestat.
The BZ99 has a boiler pressure gauge, doesn't it? The safety release valve should open somewhere between 1.6 and 2.0 bar. Note: There are some espresso machines without boiler pressure gauges and some DIY-type owners fashion a temporary boiler pressure gauge to confirm the pressure is exceeding normal operating range (i.e., using two hose clamps, a tire gauge, and short length of radiator hose hooked to the steam wand - needless to say, you can burn yourself!). That said, I suspect you already recognize the forcefulness of the steam is "turbocharged" compared to normal when these mishaps occur. If so, it's the pressurestat sticking shut and should be replaced.
beanmuncher wrote:A quick bit of googling and forum searching this morning suggests to me that my pressurestat (which is probably original to the machine, which in turn was built in '96) needs to be replaced - is this the right idea?
If you post an image of the pressurestat, it should not be difficult to identify (probably a CEME or MA-TER; see How to adjust an espresso machine pressurestat for photos).
Postby beanmuncher on Mon Nov 15, 2010 11:40 pm
Here's the pressurestat in question. I pulled it out and cracked it open - metal diaphragm and some moderate grunge/corrosion on the inside near the metal on metal seal. Scrubbed it, put it back together and tried to fire up the machine... at which point it started making the heating/hissing noises I associate with impromptu steam baths. Turned the machine off.
At a guess (from the last time the BZ99 needed major surgery), that's a 1/4" connection.
beanmuncher
Postby beanmuncher on Tue Nov 16, 2010 12:20 am
I also pulled the relief valve and had a look inside (I've pulled it several times over the last few years when this issue has come up). Flipped the plastic gasket inside (hard, white plastic held in place with a single screw) and scrubbed it but good. Machine is warming up now, just as a test.
beanmuncher
Postby HB on Tue Nov 16, 2010 8:07 am
beanmuncher wrote:At a guess (from the last time the BZ99 needed major surgery), that's a 1/4" connection.
I don't recognize the model, so I asked Jim at 1st-line about this pressurestat. He was pretty sure it's no longer made and recommended a MA-TER replacement.
Postby beanmuncher on Tue Nov 16, 2010 12:25 pm
Thanks Dan! The BZ99 seems to work for the moment, but I'm placing the order before I go in to the lab this morning.
Of course, what week does it choose to act up? The week I'm applying for three years of graduate funding.
beanmuncher
Postby beanmuncher on Tue Nov 16, 2010 12:36 pm
Just ordered one from Great Infusions - I wanted someone who was on this side of the country (or I would have ordered from 1st-line for being a great resource). I'll post again once I've got the part in hand and have replaced it.
Thanks!
beanmuncher
Postby erics on Tue Nov 16, 2010 8:51 pm
Sorry to bring this up at this time but . . . try to check the amperage ratings on the old vice the new. I'm thinking that this Bezzera machine, like its siblings, switch the heating element directly from the pstat and thus need a little meat on the contacts.
Skål,
Eric S.
http://users.rcn.com/erics/
erics
Next
Return to Espresso Machines
