Pressure pump gauge going crazy
Postby Yerushalmi on Sun Sep 19, 2010 11:57 am
When the pump on my Brasilia Mini Classic kicks in, the machine doesn't go silent like it used to (before it was repaired) now it makes almost the same noise as during the pre-infusion stage, and the gauge oscillates very fast
see here:
any ideas?
thanks!
Yerushalmi
Postby HB on Sun Sep 19, 2010 12:10 pm
My guess is that the dampening coil is filled with water. From Building a Portafilter Pressure Gauge:
HB wrote:Allow me to clarify... they're called vibratory pumps for a reason:
Image courtesy of Made in the GARAGE
How much of the 60Hz back-n-forth is reflected in the gauge depends on the machine. For example, if it has a gicleur (orifice) in the grouphead, the gauge will vibrate significantly less. The sensitivity of the gauge itself also comes into play. To dampen needle flutter, manufacturers use a coil of thin copper tubing or snubber (e.g., an inline porous stone or dampening piston).
As an example, the needle on the portafilter pressure gauge I made from Ace Hardware parts vibrated like a hummingbird's wings when used on my Rancilio Silvia. It buzzed on La Valentina (E61 with gicleur), but was readable. Of course the Scace II has a quality liquid-filled gauge and its reading is rock solid.
Rotary pumps also generate pulses, but they're barely noticeable for most air gauges with no dampening.
That is, to avoid needle flutter, espresso machines need some dampening agent between the pump and the gauge if the gauge is air filled (instead of oil /glycerin filled). The gauge in the video is clearly an air gauge.
Postby Yerushalmi on Sun Sep 19, 2010 12:17 pm
Is this something I can/ought to fix by myself?
thanks
Yerushalmi
Postby Yerushalmi on Sun Sep 19, 2010 12:18 pm
btw
Is the Brasilia a rotary pump machine or vibe?
thanks!
Yerushalmi
Postby HB on Sun Sep 19, 2010 12:29 pm
Judging from the sound on the video, your machine unquestionably has a vibratory pump. I recommend you take it to a qualified repair technician since it may be necessary to replace the gauge and/or solder in a new dampening coil; that's beyond the skills of a casual DIYer.
Postby Yerushalmi on Sun Sep 19, 2010 12:41 pm
Dan
If I just leave it as it is, will it damage the machine? It's a big shlep to the repairman (two hour drive!)
thanks
Yerushalmi
Postby HB on Sun Sep 19, 2010 12:50 pm
Other than the loss of a steady brew pressure reading, there is absolutely no harm to leaving it as-is.
Postby jasonmolinari on Sun Sep 19, 2010 3:10 pm
My Isomac Tea exhibited a similar pressure gauge flutter.
I took the gauge and connected dampening tube off and applied heat to the tubing carefully with a blow torch. Water sputtered out the end of it. Did that until it seemed dry.
that fixed the problem...
Careful not to get too close to the gauge with the torch!
jasonmolinari
Return to Espresso Machines
