mitch236 wrote:Does anyone have an idea about how to control the speed of the pump? Is is possible to get a slider to control speed much like a paddle?
Both the TMFR pump and all the gear pumps I have seen at least have options to have a 0-5V control input that sets the speed. In the case of my TMFR pump, there's an on-off signal separate from the 0-5V signal, meaning that 0V will deliver the minimum pump speed if the pump's on-off signal is on. From drawings I have seen of the gear pumps, it looks like they have no distinct on-off signal, and turning the pump to 0V will turn it off entirely.
To push a signal to this, you'll need either a PID that has an analog 0-5V output, or you can make your own with a 5V power supply and a potentiometer or rheostat. On my setup, this is basically a "volume" knob for pump speed (indirect pressure control), like you can see
here.I had a chance to check out the La Marzocco USA offices/warehouse/showroom when I was in Seattle a week ago. They showed me the controller that they use, and from what they said you couldn't exactly wire it straight to the gear pump: in the Strada EP's case, it connects to a brain box that interprets the signal in some way to translate it as input to their profile recorder, PID, and whatever else. The guy I talked to didn't appear to be an expert on the machine, though (most of the company was in Milan for Out-Of-The-Box), and it may be that this thing could be repurposed on the top of a standard GS3 and wired into a custom, directly-coupled, manual pump setup.
