by godlyone on Tue Jan 19, 2010 2:24 am
Tom, I don't have such an elaborate rig like you guys.. but just for kicks I manually pressure profiled a few shots.
My water inlet is on a T with a water faucet (like for filtered water for drinking):
mains------|--------FILTER ------- rotary pump inlet
.....kitchen faucet.................|
..........................drinking water faucet
So if I use the drinking water faucet (will abreviate DF) I can change the pressure the pump inlet sees
Since my Brewtus II is an e-61, If i put the lever half-way I get line preinfusion
so for the test shots, I turn DF on full, then lift lever half way [pressure is near 0], slowly close DF.. pressure nears 4 bar (my mains pressure), then when DF is fully closed, lift lever fully to activate pump
If I do this, the shot seems to strangely blonde a lot sooner than if i don't use DF at all and just go from 4 bar straight to 9
I know that I can't run the pump with DF open and of course I don't do that - I'm just talking about during the line-level preinfusion stage
so my results are consistent with yours (which is strange to me as I thought a slow ramp up would yield a longer shot)
