It's not that I care what the numbers are 134 Vs 9.24(grey arrows), visually it's easier to read from the gauges I've found. I've been profiling my pressure for a while now, and seen how different coffees sweet spots can differ if only slightly. For example(subjective of course)Hairbender, pre-infusion 19 psi top pressure of 127psi Vs. Lighthouse Roasters Espresso blend pre-infusion again at 19psi, but tops out at 122. Both of these also have a ramp down pressure.
The pictured gauges are of similar pressure ranges, all marks should be roughly the same. What would you rather be reading from? I've cataloged quite a bit of data on different profiles for different blends, and wouldn't go back to bar myself. Next I'll be using the computer to data log, but still like to have the analog visual of my gauges.
John
