ginalola wrote:.... I may be using it in a couple of weeks; if not, then I will need to take more drastic measures.... What is the effect of a humid environment...like in a New England lake house during the summer months...on this machine? It will be going in and out of air-conditioning.
It should be fine. A couple of weeks storage, even if water is left in the lines, shouldn't be a problem at all, IF:
1 - Fresh water is run through the machine after it is allowed to heat up before being put back into use.
2 - If it is not being stored where it will subjected to freezing temperatures.
For extended storage in humid climates, precautions should be taken to keep out pests and vermin.
