mitch236 wrote:I was thinking that I could add a water line that goes in to the steam boiler and then back out to the brew boiler. Would this work?
This is exactly how some DB machines work, like the Izzo Alex Duetto II (as well as the Brewtus III, not sure for this one).
See the Bella Barista Closer Look (3.5MB PDF):
http://www.bellabarista.co.uk/pdf/IzzoAlexDuettoIIcloserlookv4.pdf,
schematic on page 3 and multiple pictures where you can see the steam boiler HX outlet to the brew boiler.
There are issues with doing this. In contrast with a regular HX machine, you cannot flush the HX over-heated water... it always ends up in the brew boiler. The HX needs to be appropriatly configured such that it:
- avoids bringing too much over-boiling water (which sat for too long in the HX) into the brew boiler
- and at the same time still preheat cold water enough to be useful.
Izzo indicates that they found a custom and undisclosed way to address this... (see page 8 of the same PDF).
Also, if you intend to add the flexibility of turning off the steam boiler (for economy/heat production reasons), this will also affect the water temperature coming to the brew boiler.
Louis
