Post a pic of your home espresso setup... - Page 454
- BaristaBoy E61
spiffdude wrote:That black box is the transfo for my LED lighting, i had to hide it somewhere!
I have an in-line pressure regulator that keeps the inlet to the machine at 30 psi. I don't know that the Rocket allows for line preinfusion? I always though that it would only let water pass when the pump is engaged and then you get the typical e61 head preinfusion at full pump pressure.
The 45° position of the brew lever should allow for water line level pre-infusion. Try it. You might notice a slight drop in water pressure reading on the 'Pump Pressure' gauge. I can see by the picture you posted that it already is reading a water line pressure of about 4-Bar. Lifting the group lever to the middle or slightly higher position - but before the pump engages should initiate water line level per-infusion. Watch the pump gauge and listen for the sounds of water flowing. It should take about 6-seconds to pre-infuse the puck and for the first drop to hit the bottom of the cup, then lift the group lever to the 90° position (parallel to floor) to engage the pump. You can end with a line level ramp down or go all the way down to open the group valve to release pressure completely.
YMMV
After a few entry level machines and grinders I am happy with where I am at. My house was built in the late 90's when it was apparently popular to have a large cabinet that could house an old tube television. It has become my espresso cabinet. When not in use, the door folds down and covers everything.
- FotonDrv
There used to be old typewriter cabinets that allowed the user to fold the very large heavy legal typewriter into the cabinet. Pretty useful mechanism!JohnStuartP wrote:After a few entry level machines and grinders I am happy with where I am at. My house was built in the late 90's when it was apparently popular to have a large cabinet that could house an old tube television. It has become my espresso cabinet. When not in use, the door folds down and covers everything.
<image>
- spiffdude
I will try that out tomorrow morning for sure. Thanks for the tip!BaristaBoy E61 wrote:The 45° position of the brew lever should allow for water line level pre-infusion. Try it.
Damn this forum, I've had too m..muh...mah..mmmm..much caffeine!
Thanks! I have always been a fan of Elektra's styling, and they make for good conversation pieces. Over the years I have been lucky and able to acquire some broken ones for cheap.Ppettson wrote:Really nice work Espressonut! Looking excellent!
- FotonDrv
Welcome Blake and a nice first Post showing that good coffee can actually happen On The Road
- Supporter ★
I recognize that setup The monolith flat and CT1 look great next to one another. Excellent pairing.
