Post a pic of your home espresso setup... - Page 434
- drgary
Cecil,chappcc wrote:Just finished repairing an Elektra La Deliziosa, vintage 1998, that I picked up on eBay as a parts-only machine.
I love the look of that Elektra in copper! Great find, and thank you for showing it to us.
LMWDP#308
LMWDP#308
That is a beautiful machine! Our old home had a big country kitchen and the light fixtures were all antique copper. They don't fit with our current home so they are in the basement, but maybe one day they will get used againchappcc wrote:Just finished repairing an Elektra La Deliziosa, vintage 1998, that I picked up on eBay as a parts-only machine.
<image>
To get the machine to work on a timed circuit, I used a Z-wave switch as an on/off timer controlled by my Z-wave controller. I installed a 60 amp solid state relay (on the machine's hot AC line); this is controlled by a 12 volt DC transformer plugged into the Z-wave switch. This was a lot cheaper than buying a higher power switch/timer. My Z-wave switch could only handle 1500 watts and the Elektra has 2200 watt heating elements. I have an available 20 amp outlet for the machine.
I've been pulling shots following a 4 second count after the steam subsides during the flush of the heat exchanger. I grind 18 grams in a VST basket to get 30 grams of espresso in ~30 seconds. I used a naked portafilter to verify no channeling or spritzing. The resultant espresso taste is comparable to that I get from my Salvatore Compact Lever.
The Elektra rotary pump produces ~9 bar with a blind portafilter basket so the grind for the Elektra is not as fine as needed for the SCL. The SCL produces ~11.5 bar with a blind portafilter basket.
...ron
LMWDP #356
LMWDP #356
- Almico
Almico wrote:New espresso cart arrived. Now just waiting for its K10 cart-mate.
<image>
Perfect. You can crank the temp of the house down a couple degrees before your start loading up in caffeine...
- Almico
Ha...I might have to move my thermostat. The heat may never come on while the machine is going!RyanJE wrote:Perfect. You can crank the temp of the house down a couple degrees before your start loading up in caffeine...
- jchung
Get an Ecobee3 w/ remote temp sensors. Best smart thermostat out there for a larger home and uneven cooling.
- Almico
Old house. Not wired for smart thermostats. Only 2 wires.
- jchung
Well that sucks... next time your HVAC guy is out... might want to ask him about running a new set of wires... at least 2 more if not just a CAT5.
