I agree with Mike and its relatively easy to check. With the machine cold and unplugged:
a. Put the brew lever in the brew position
b. Use a 1-7/16 open end wrench to remove the preinfusion AND drain chamber assembly as a unit from the grouphead.
c. The preinfusion valve assembly will simply lift right out.
It is part number F_223 shown here:
http://www.espressoparts.com/cate...ma.e61manualgroup/Inspect the top square pin for a groove worn into its surface from the cam. Excessive detergent backflushing can wash away lubricant films accumulated on the surfaces and aggravate this wear.
The total length of the assembly for the Vibiemme machines is 2.406 inches or ~61.1 mm. Note that Vibiemme groupheads are slightly different than the "standard" E-61 group and the part I referenced may/may not be the proper part. The Vibiemme expert close to you is this nice guy:
http://espressocare.com/
