I've been plagued by a leaky grouphead at the portafilter.
I changed the seal thinking that would cure it - nope... Tried a spacer to tighten everything up - nope...
What I have noticed is that the portafilter isn't centred on the seal and just clips the edge of the seal on one side. I have now tried locking it in the centre and it's a lot better but not perfect.
The outside diameter of lugs/tabs of the portafilter is 80mm but the diameter if the grouphead slot is 85mm.
Should the portafilter lugs be 85mm (ish) too?
p.s. It's nothing to do with the basket being too full as I'm testing it using a blind basket. Any excess pressure should get dumped. The pressure is spot on 9bar as I have an inline gauge in place.
