JmanEspresso wrote:AHHH.. A Harry Potter fan I see! I can recognize that font a mile away.
Not really, my kids are. It was the only book handy for a reflection photo. My reading is limited to service bulletins, Microsoft security updates, avert labs virus updates, VM ware and other exciting tech documentation.
If you have some bad scratching or oxidation, you can use cloth wheels on a bench buffer. Hit it with tripoli to clean it up, then white rouge, red rogue, and then 0.5 micron chromium oxide. If the scratches are very deep than sanding them is the only way to remove them, then the polishing compounds to buff it back out. Not all sandpaper is created equal, for stainless you need aluminium oxide paper or harder. Cheap wood sandpaper will do nothing, the grit is not hard enough to cut steel. You have to go very high in the grits as well. 400, 600, 800, 1000, 1500 and 2000 minimum. if you want a real mirror polish you will end up having to go into micromesh and run up to at least 8000 grit. I usually go to 12000 then the compounds. You can also purchase greesless grits to apply to buffing wheels for sanding as well.
