yakster wrote:Any warnings for buffing with polishing compound?
you need to make sure you're using the correct compound and the correct hardness/stiffness wheel for the metal you're polishing. If you're polishing metal that is plated, you can strip right down through the plating if you use too aggressive a compound or too stiff a wheel, so make sure you know what you're polishing first (remember all chrome is plated on, so be careful when polishing it) The dremel is ok for small stuff, but for large stuff the wheel is too small and you'll likely end up with streaks, plus it will take ages to finish. The good news is you can always start over, just make sure you go through the compounds in order.
The golden rule (or one of them), is to only use one wheel per compound to avoid contamination of compounds/grits. Another thing that was easy to learn, but hard to practice it to let the compound do the work, not the wheel, meaning don't use excessive pressure if you're not getting the results you want--you likely just need a different wheel/compound.
What part of the peppina are you planning on polishing? i don't think it will work well on painted surfaces, but will probably work great on the drip tray.
good luck, polishing is one of the most rewarding things i've picked up in espresso restorations.
-mike
