by coffeerv on Thu Jan 26, 2012 8:05 am
Most if not all electronic water level sensors measure the resistance of electrical current to GROUND. Reverse Osmosis usually doesn't and distilled water doesn't have enough minerals in suspension to provide a short circuit to the grounded metal body of the appliance. Pure H2O does not conduct electricity. Thus the sensor can't SEE (tank full) or NOT see (tank low) the water when it touches probe tip. Some minerals also provide aid for the extraction of some of phenols in the coffee oils. The lack of them can diminish some of the flavor in a minor way. Since water is 97% + of the finished brew, addressing specific water problems, ie scale, hardness, chlorine, manganese, whatever, should be done with specific filters. Softened water should be avoided. The minor amount of salt that MAY get through a poorly maintained unit to the coffee can turn some extractions into snot and plug the basket in the worst case.
I can't fully explain why, but the line from a drip tray must have an air gap to the building drain. This is not a device, it is literally a gap allowing the line to DRIP into the drain. I have often seen the lack of this gap cause the drain line to clog over time or not drain at all. Many installation manuals state the need but don't explain what constitutes a gap.
If you can't explain a complex idea in simple terms, you don't understand it. Einstein
