I recently (this past Monday) received a new Andreja Premium (upgraded from Silvia). It worked fine on Monday (I thought at the time) but it wouldn't work Tuesday morning. In talking to the techs and doing some troubleshooting it seemed to be the heating element which they sent and I received today. When I pulled the old one out it was burnt/broken right at the top. I installed the new one, hooked it up, went through the new machine start up procedure again, and got heat (and therefore boiler pressure).
Here's where the trouble (maybe) starts. When I open up the hot water wand I get a bunch of black water...probably not a good thing. What bothers me even more, not having had an HX machine before and not fully understanding what does what for certain, is that I can run the hot water wand until I have no more water coming out but it doesn't seem like there's anything happening (like the pump running) to refill the boiler. When I run out of water am I not really pulling the level down far enough to need a boiler refill?
When I turn off the machine (for maybe for 15 or 20 minutes) and come back and turn it on again the pump starts running then. In fact a few minutes ago it ran for longer than the 30 seconds the instructions say to let it run so I turned it off and waited the recommended 5 minutes. I just went back and turned it on again and the pump started up once again; this time it shut off after 15 seconds or so (so I assume the boiler is full at that point).
I'm really worried that if the boiler level falls that the machine is not refilling as it should. Obviously this would likely lead to the burnt heating element. What is it that controls the boiler filling procedure? And how do I know if it's working? As I understand it lifting the brew lever only runs water through the HX, correct?
I'm so frustrated! I'm ready to ship the darn thing back and fix my Silvia and of course it's Friday so I won't be able to contact the techs until Monday. I'm hoping someone here has some thoughts (good or bad) about what's working and what isn't. I'd sure like to convince my wife this weekend that spending this much for an espresso machine wasn't really a stupid idea!
Thanks in advance for all your comments, ideas, and guidance.
