by godshot on Fri Jan 21, 2011 7:28 pm
Does anyone know what pipe thread standard is used for the input water supply line on the direct connect Vibiemme espresso machines? The hose terminates in a male threaded fitting. How about the Inoxdep rechargable water filter that is sold by 1st-line? It has a male fitting for input and output. Both items are manufactured in Italy, so unless it was specifically modified for the US market, I imagine it's whatever is normally used in Italy.
I called 1st-Line tech support today and was told that they were "metric threads". I found a metric thread standard ISO 261, but that seems to describe screw threads rather than pipe threads, as best I can tell. Home Depot and Lowes and similar stores only seem to carry NPT fittings. I know I can get most anything that is made from McMaster Carr. I don't want to use the wrong type of fittings and risk damaging the existing threaded fittings.
1st-Line has a 1.5 meter hose with female couplings on both sides and a female/male adapter that I can use to extend the water line on the VBM and connect to the output side of the water softener. But I still need to know the pipe thread standard, at least for the water softener, so I can connect the input line to it (output from my sediment and charcoal filter).
