by erics on Sun May 24, 2009 11:49 am
As you are posting, what controller is installed in Silvia? If it is the Delta, shut the machine down and reinstall the Love. The only wires you need to be careful about are the + and - wires going to the solid state relay (SSR). These need to be correctly attached.
Does the machine at least heat up now? If so, to what temperature? Other than not being adjustable, is everything else OK?
