ok, thought I should post a quick update for anyone in a similar situation. I have converted the pasquini to 220v, however there seems to be another problem with it, takes a minute to get an espresso out of it. so i've got to work on that. but that's another bit of investigation to do another time when the house is finished!
Peter Bradley,
http://www.spanglefish.com/avicennassol...eid=240390, did the conversion for me. peter fixes coffee machines for a living and specialised in la pavoni machines. if you're doing a conversion i really would recommend he gets the parts and seals for you, it'll save you alot of bother dealing with suppliers.
I was just going to get him to get the parts and fit them myself. but then my girlfriend gave birth early so i figured it best to concentrate on getting a working kitchen in place instead! so, Peter did the conversion with parts direct from suppliers in the UK (not olympia). i think the heating element was one he already had in stock.
here's what was charged:
Spare Parts Qty Ea Price VAT Total
ODE 3 way valve 240v coil £18.62
ODE postage £3.60
FluidOTech 240v coil £20.47
FluidOTech postage £6.00
Supply and fit 240v element £34.99
There is a company in UK who deal in FluidOTech.
http://www.becktech.co.uk/fot_overview.phpODE have a distributor in UK
Avalco LTD
02476 350958
http://www.avalco.co.uk240v Coil pack for ODE 31AV1AV26-33 3 pin out, max temp 120DegC. Also seal kit for same
so, the three parts he change wire, the ODE 3 way valve coil, the pump coil, and the heating element.
please note it's the coil and not the whole parts that were replaced.
hope this helps, PM me with any questions as for some reason i don't get notifications from HB.
