I found this label that fell off inside the machine but I am not sure where it came from as I don't recognize the brand. If it's the brand of the pump, does this mean that the pump has a max flow rate of 6 bars?
Here's my sequence to testing the flow rate, though I didn't have to let the machine heat up:
1. Turn on machine and activate the brew switch to allow water to come out of the group
2. Allow machine to heat up for 15-20 minutes
3. Turn pump on for 30 seconds with nothing in the group head
4. Water flows normally for a few seconds and then within 5 or 6 seconds, it slows down to a few drops.
5. In another few seconds, the flow resumes again but at a reduced rate
6. At the end of this 30 seconds, I get about 180 ml
Later, in another sequence:
1. Turn on pump for about 5 seconds to where the flow starts to slow down
2. Turn off pump and wait for 30-60 seconds
3. Turn on pump for 30 seconds with nothing in the group head
4. Very little water for the first few seconds then reduced flow and I get about 125 ml
The weird thing is, the grind that I used is within a mark or two (Wega/Compak K10) of what I used for the 58mm VST basket and I get about 2 oz of espresso in 30 seconds with beautiful crema. The taste is noticeably lighter than my E61 machine but still very tasty. I am still using the plastic tamper so that could be it as well. Using a foam cup, the K-type thermocouple shows that the water temperature in the cup is about 190 deg F. The group head shows about 170-175 deg F at idle though I didn't use the appropriate tape to secure the leads. Looks like the previous owner knew what he was doing because the pstat is adjusted all the way down in its travel and the 3-way solenoid outlet to the drip tray is already turned 45 degrees inward to minimize splashing. Well, more info than needed but please give me your take on the pump. Thank you.
