Hello:
RAS wrote:... the pump may be okay.
... need to prime many Olympia pumps, and the horrible racket they can make until they are primed.
Indeed ...
In my limited experience, what I
can say is that
all the Ulka pumps I have come across made a 'horrible racket' when water was not getting to them and were pumping 'on empty'.
This is probably a common trait to all vibe pumps. If a vibe pump is making a loud noise, it is because it is working but the plunger is banging back and forth without water inside the line to offer resistance, softening the movement and muffling the sound as the water passes by and pressure ramps up.
There's a very interesting blog started by a fellow by the name of Rod Schiffman (aka Brownbag), where you will find quite a bit of information about Ulka pumps, how to take them apart, clean, etc. See here:
http://ulkapumprepair.blogspot.com/.
These pumps are very easy to service although there are some who think it is better not to waste time doing it and just replace them as there are no spare parts for sale anywhere. I think otherwise and have revived two or three with just a good cleaning in white vinegar.
A pump with a burnt out coil (there's no replacement available from Ulka) is an excellent source for spare parts.
Caveat emptor: you must be very (
very) careful when taking one of these apart as although they have few parts, some of them are very tiny and prone to jump about, getting irremediably lost in the process. Believe me, I
know. =^/
Hope this is useful to you.
Cheers,
CIV
