http://www.kitchen-universe.com/detail.aspx?ID=4447
The new Livietta T2 is not yet listed on Pasquini's web sight, so I was curious and emailed Pasquini for information. It is based on the original Livietta design but made by Pasquini not Olympia; however, it has many novel improvements over the old design. I was really impressed by the price assuming it has the same quality as the old Livietta/Olympia Maximatic. Here is the list of features emailed to my by Pasquini:
The Livietta T2 is the latest Home Machine from Pasquini. Like all Pasquini espresso machines, the Livietta is made to be used like a commercial machine. One may Steam milk while brewing espresso at the same time.
Features:
1. Small Foot print, 8.5" wide, (12.5H x 14.25 front to back)
2. Fast heat-up, 2 min for coffee, 1.5 min for steam.
3. Easy To use
4. Pull out reservoir
5. Seal less Solenoid Steam valve.(No maintenance)
6. Slow Start Steam, for added control and Safer to use
7. "Easy Foam" Tip
8. High polish stainless coachwork
9. Anti Rust powder coated inner-frame
10. Brass, Filter holder and Bell
11. Cup warming area
12. Large work area
13. 120 Espressos per hour
14. 15 Bar pump (220 PSI)
15. Commercial performance, allowing for coffee and steam production at the same time!
16. High efficiency heating systems, for energy savings usage (1400 Watt)
17. Machine can run dry, because of Dry Production Technology (DPT)
18. Easy to de-lime
19. Self priming pump
20. Okay to leave on all day.
21. Pull out, Large capacity drain basin,
22. Heats 8 Oz of cold milk in Two Minutes.
23. Only one wear and tear seal in entire machine, End user maintenance.
24. ESE available for pod usage.
