Long time lurker here. I have been given an old Paquini single group machine by a client that does renovations. It has had a hard life and at some point was dropped or somethig fell on it. The frame is bent a little bit, a few of the stainless steel body panels are bent, and one of the cast aluminium panles is cracked and has a corner broken off. That said, I pulled the side, top and back panels off and it looks pretty clean. It powers on, I hear a few clicks and the water level light (at least I think that is what it is) turns on. The brew bottons all work when pushed. It is a La Cimbali M-27 under its skin. I am fairly mechanically inclined and would love to get this machine running and put it into the shop. Coffe and cycling go hand in hand.
I have a few questions to start with.
Does anyone have a manual for this machine that they can email? Both an operating and a repair manual would be great.
Does this have to be plumbed to pressurized water? Can the pump pull from a non pressurized tank?
Is there a way to manually fill the boiler? I would like to try to run it before I tear it apart to see what issues it might have.
Any help or advice is greatly appreciated.
Andrew
