Gregg K wrote:David, thanks for the tip. I forgot about connector issues. But I have just pulled and plugged back in the connectors for the boiler, and the light is still on.
I was thinking more the probes (=the bit that extends into the boiler) than the external connector. The water level probe (for example) can scale up and stop reporting correctly, or can slip in its holder and end up not being as deep as it should be.
I don't know enough about electronics to know what the triac does.
A triac is like a relay, it uses a small current to control a larger one. I believe triac failure in the Techno triggers a more spectacular light show (at least, mine did way back when), and would also switch off the machine.
David R.
