Owner experience with Dalla Corte Mini - Page 3
You don't really need a guide to use the DC Mini. You can get the Info you need on the net.
The Preinfusion isn't really preinfusion but rather pre wetting. A very Odd and useless invention that most vibration pump machines have. If I where you I would forget about it, because the impact it has on the end result are close to none.
Preinfusion are only useful on machines with a Main water connection.
So don't waste your time on it. Instead use the time you have on dosing and distributing. It's a little bit different compared to the Classic 58mm filter basket.
