Owner experience with Bezzera Strega - Page 107
Crap! Mine is exhibiting the on/off sensor issue pretty consistently now. Was going to pick some of the Arctic Silver 5 today and was hoping that would solve the problem, but if not conductive, I'm not sure it will....wonder if the fine sandpaper mentioned a couple pages back is a better option?DanoM wrote:Hmmmm... I put that on the contacts of my Strega, and from the time I put it on there I've had zero problems with the sensor clickety-clak issue. When I first did that I thought it was an electrically conductive paste, but that turns out not to be the case after looking into it further.
My guess is it keeps dissimilar metals from corroding when in contact. If that's the case petroleum jelly would probably work too.
I have fixed this issue by pushing the metal tabs (that press against the tank) inward a bit so that when the tank is put back, there is more pressure against the metal screws on the tank. This seems to have fixed it (for nearly a year so far); now every time I wash the tank (couple of months), I push the tabs inward slightly before putting the tank. It may not work forever (I assume at some point the tension may not be enough?), but doesn't require any mods.mixedup wrote:Mine is exhibiting the on/off sensor issue pretty consistently now.
FWIW, I pushed the tabs in slightly and fired it up. Problem seems to be fixed, so potentially just a tension/contact issue. It did seem to start when our weather got colder and was possibly enough to contract the metal parts so the connection wasn't great.
I'll see what happens tomorrow morning....I did drop $10 on the paste but may not even need to try it.
Scratch that....fired it up this morning and the on/off water sensor issue resumed. Pulled the tank and put a dab of the Arctic Silver paste on the screws on each side of the tank and the issue stopped happening. Whether that is due to the paste or the reseating of the water tank, who knows.
Will keep my eye on it the next few days, but hoping the silver particles in the paste have improved the conductivity and solved the issue.
Yeah, my Strega has been working great without any issue since I put Arctic Silver paste on my tank contacts a couple of years ago. Works for me, although I'll admit I haven't tested the conductivity of the product. My guess is it inhibits corrosion at the point of contact. Who knows...
LMWDP #445
That seems to workmixedup wrote:FWIW, I pushed the tabs in slightly and fired it up. Problem seems to be fixed, so potentially just a tension/contact issue. It did seem to start when our weather got colder and was possibly enough to contract the metal parts so the connection wasn't great.
Jim i need your help..i have made these question again.I want to do a descale to my strega after 9 months.The reason i want to is that i saw some saults inside the shower.How do i do descale and with what?Citric is good enough or i will need something stronger?
- another_jim
I use two table spoons citirc acid per liter water. There are lots of descaling instructions, use the search function. For the Strega, if you want to siphon the descaler in and out of the boiler, use the tap for the steam wand; it has a larger hole than the one for the vacuum breaker.
Jim Schulman
Jim how do i take water out of steam?should i take out the yellow cable of the heat probe?how many times do i have to do it? One is enough after one hour waiting?If there is any video i would love to see it.
- another_jim
You need to study the descaling instructions, or ask someone to help.
Jim Schulman
