Original E61 group cam differences
ertech
#1: Post by ertech »
Hi guys
Trying to rebuilt the group
Received 2 different cams one with and one without pin at the end . The problem is the lobe is bigger than my original one. I am sure I have the correct one since I compared with someone local who has the same machine.
Anyone knows where I can source an original one.
The bigger one binds
Thanks
Erick
BaristaBoy E61
#2: Post by BaristaBoy E61 »
Have you tried Faema or Café Union on Jean Talon West, or Espresso Mali on St-Laurent, all within a very short distance from each other?
ertech (original poster)
#3: Post by ertech (original poster) »
Yes even espresso mali
You have a E61?
BaristaBoy E61
#4: Post by BaristaBoy E61 »
Yes I do have an E61 Izzo Alex Duetto III that was purchased at Chris' Coffee. Maybe they might have a suggestion.
Looking at your interests, might you know someone with a machine shop that could make one?
I'd be glad to help if I can think of anything...
#5: Post by ertech (original poster) »
Yes but if I bring my worn one there they will replicate it
So I wont have the right measurement
Send me a pm. Would be great to have a coffee
I live in TMR
erics
Supporter ★
#6: Post by erics »
https://www.espressoparts.com/parts/com ... ad-cam-rod
But you really need to develop a "bucket list" as shipping can be expensive for single parts.
Skål,
Eric S.
http://users.rcn.com/erics/
E-mail: erics at rcn dot com
#7: Post by ertech (original poster) »
Thanks Eric
Was told by Ryan at espresso parts that with or without pin measures the same. My cam is smaller
erics
Supporter ★
#8: Post by erics »
Well, . . . OK.
It seems as though you need a cam that does NOT have the pin extension UNLESS you have a machined hole in the cam housing. The larger extension of the cam (your original part?) simply serves as a spacer to properly position the cam with respect to the brew valve and pre-infusion valve.
Take some pics and measurements of your cam housing diameter and I can measure mine. Also measure the length of your valves.
Skål,
Eric S.
#9: Post by ertech (original poster) »
Here are the measurements
The housing is 27mm
Thanks
erics
Supporter ★
#10: Post by erics »
I took measurements of a Quickmill Anita fitted with a standard E-61 grouphead. Considering the cam to be a modified oval, the following applies:
Major Diameter = 20.32 mm
Minor Diameter = 17.15 mm
Housing Bore = 28.20 mm
On previous measurements I made, the cam lifts the brew valve 1/16" or approximately 1.60 mm.
What exactly is "wrong" with the original cam you have?
Skål,
Eric S.
Post Reply
