After googling it seems like the standard pressure for a extraction is 9 bar, but this was impossible to get on my machine, if lower pressure - too high flow. So I decided to put an extra OPV that regulates the pressure from the pump. The built-in OPV is strangely placed *after* the boiler, so using that to regulate pressure would result in a very unstable boiler temperature.
I have now added the OPV and tried at 9, 10 and 11 bars. The acid taste is gone, much smoother in taste but a bit weak, less and blonder crema.
Most machines that do pressure regulation at 9 bar seems to be more professional machines, with E61 groups and larger diameter PF's. Is there any consensus on how and if the PF diameter affects the optimal extraction pressure. Using same amount of coffee (i use 14g) the larger diameter will result in a thinner coffepuck, which could indicate that a higher pressure is suitable.
Wisdom on this matter appreciated
Isomac Brio Modficiation:
