www.zokacoffee.com: you're original, drink like it - single origin & artisan coffee
One week with the La Marzocco GS3 - Page 2
Postby another_jim on Wed Jul 05, 2006 2:19 am
If you're in a debunking mood, Dan, or at least a tough one, serve some blind paired shots during your weekend jam. Generally a series of 5 shots per taster will reveal whether there is a big difference. For small but real differences, you have to go out to about 20 to 30 shots, not really possible for a weekend.
Your parallel test at CCC showed no large differences between the Linea, Junior and E-61 box; so if the GS3 does show a big one, it would be major news.
another_jim
www.veniacoffee.com: purveyors of specialty coffee and exceptional equipment
Postby AndyS on Wed Jul 05, 2006 5:42 am
HB wrote:What was a surprise to me, given my prior experience with La Marzoccos, was that the GS3 produces such good results with less difficulty then its siblings.
Bill Crossland describes the GS3 as an "easy" machine. I believe he says that it may or may not make better espresso, but it definitely makes it easier.
Question: do the Lineas have the same drilled-out dispersion screw? Or is that new with the GS3? I think it's a very good design because water enters the area above the screen so well dispersed.
On my tricked-out Silvia I can set the water debit and extraction pressure wherever I want, but I still often get flow weighted towards the front of the puck. This appears to make sense, because the water path into the group is pointed to the front by the way the head is drilled. Not so with the GS3.
-AndyS
VST refractometer/filter basket beta tester, no financial interest in the company
AndyS
Postby darrylr on Wed Jul 05, 2006 6:52 am
Yes, Lineas use the same kind of dispersion screen.
Darryl
darrylr
Postby miKe mcKoffee on Wed Jul 05, 2006 1:27 pm
Nice video work Dan. Takes naked porn to a whole new level compared to glossies. :!: :lol: Might be nice to have both the PF and clear demi in the videos if possible.
Mike McGinness, Head Bean (Owner/Roast Master)
http://www.CompassCoffeeRoasting.com
miKe mcKoffee
Postby HB on Wed Jul 05, 2006 1:57 pm
another_jim wrote:If you're in a debunking mood, Dan, or at least a tough one, serve some blind paired shots during your weekend jam.
That's definitely on the agenda, though I don't expect a big turnout given the holiday and short notice. Lino is coming by tonight to hook up the Mr. Wizard Kit (temperature and pressure profiling). The GS3's temperature performance has been exhaustively documented, but I don't recall anything about the start/stop preinfusion and the resulting pressure profile.
miKe mcKoffee wrote:Might be nice to have both the PF and clear demi in the videos if possible.
OK, next time I'll get out the Illy Nudes and put them on a "booster" to get them in the frame. In the meantime, below is a demonstration of my feeble photography skills:
Washed out by the flash, bad exposure,
sat for a minute... but still quite tasty
Postby Teme on Wed Jul 05, 2006 2:36 pm
HB wrote:If you're desperately looking for reasons not to buy a GS3, I would put poor ergonomics at the top of the list. Was the product designer left handed? Or is the machine's compact nature force compromises due to interior room constraints? The workflow from brew-to-steam is clumsy:
  • Steam arm is on the left, toggle control is to its right
  • Brew controls are on right, opposite side of the grouphead.
  • Steam arm doesn't reach the driptray (must purge into a steam pitcher)
And while not part of the ergonomics proper, the programming could be politely described as "Byzantine". I was able to piece it together with the help of Chris Tacy and Andy Schecter. Inexplicably, the least-often changed settings are first in the program cycling. Brew temperature is buried near the end... let's hope they revisit the ease of use in the production version.
I am under the impression that some of these have been fixed for the production model. Among other things:
a) the production model's steam arm moves freely and can be placed over the drip tray
b) the production model's drip tray is larger
c) the keypad and programming should be more user-friendly
This doesn't help regarding the location of the items, though.
Br,
Teme
Teme
ancap-usa.com: quality Italian porcelain coffee serviceware in the USA
Postby HB on Wed Jul 05, 2006 3:02 pm
Teme wrote:the production model's steam arm moves freely and can be placed over the drip tray
The arm rotates in a horizontal plane but is several inches above the driptray. I doubt they would want to make the steam wand reach lower than it already does. Despite the disappointing steam arm ergonomics, the quality of the microfoam is excellent. You would have to try really hard to screw it up.
Postby Teme on Wed Jul 05, 2006 3:13 pm
HB wrote:The arm rotates in a horizontal plane but is several inches above the driptray. I doubt they would want to make the steam wand reach lower than it already does. Despite the disappointing steam arm ergonomics, the quality of the microfoam is excellent. You would have to try really hard to screw it up.
I was at the factory two weeks ago and they had one of the prototypes there. From the discussions there I did understand that also the movement of the steam arm was to be redesigned for production. I may have misunderstood, though...
Br,
Teme
Teme
Postby HB on Thu Jul 06, 2006 12:56 am
Few rotary pump espresso machines have an inboard water reservoir, but this is just one of unique characteristics of the GS3.
As Ken and Jim documented in How to Preinfuse; Extraction Pressure Redux, there is arguably a benefit to preinfusion under mains pressure ("At 3 bar, good stuff is happening, the water has enough pressure to go through the whole puck in a reasonable time."). That's not an option for espresso machines drawing water from a reservoir, but the GS3 does provide start-stop-start preinfusion by closing / reopening the grouphead solenoid in the early seconds of the extraction.
Lino stopped by this evening to help plot the GS3's pressure profile resulting from this design:
The "speed bump" is the on/off pulse
The thread Pressure profiles, preinfusion and the forgiveness factor shows the pressure profiles of several other espresso machines. This profile resembles the Elektra A3's no preinfusion design, except for the small speed bump and a less inclined rise, presumably thanks to the GS3's smaller diameter gicleur. Lino and I were surprised to see that the group depressurizes and repressurizes after the preinfusion cycle. I programmed in one second of pressurization followed by two seconds of dwell time. While I haven't tried it yet, I assume that allowing much longer would mean a higher rise and fall, which could disrupt the puck's adhesion. Given the GS3's already easy nature, I wonder if it would improve further still with a higher pressurization to 3 bar and no depressurization as How to Preinfuse advocates?
With the Wizard Kit tucked away, Lino and I turned to pulling shots for the next hour or so. Both of us noted an ashy finish from the get-go and went about diagnosing the cause.
    A brief interlude before continuing today's report...
    Peter mentioned they had not changed the brew temperature since the GS3 was delivered and that it might be running a little cold - I believe the display said 200.3F when I picked the machine up on Monday. Lino had borrowed my thermofilter, so I couldn't confirm the temperature by direct measurement. The taste of the Toscano indicated the brew temperature was a little too hot, not too cold, and over the course of two days I've worked down ~1.5F to 198F, as displayed on the control panel. Earlier today, the discrepancy between the displayed and apparent brew temperature prompted me to e-mail two GS3 beta testers to ask if there was a programmable offset, and if so, how does one adjust it. [The Expobar Brewtus has an offset to compensate for the difference between the measured boiler temperature and the (displayed) grouphead brew temperature; for the Brewtus, it's a 6-7F delta, depending on who you ask.] Neither was aware of a programmable offset. No problem, I would continue to treat the displayed temperature as "N" and adjust by taste until Lino arrived with the thermofilter.
Sorry... back to Lino, Dan, and the inexplicable ashiness. At first we blamed the extractions; they started a bit dark and ended a bit light. Changed the grind, updosed, downdosed. We even changed baskets to the our more familiar Faema-style instead of the stock La Marzoccos. Still, the ashy aftertaste remained. :?
Finally the 15W lightbulb that was hovering over our heads increased to 25W: What about the temperature? Afterall, if someone reported problems with ashy flavors in the forums, what would be the diagnosis? From The Home Barista's Guide to Espresso:
another_jim wrote:Ashiness: Usually a flaw in rapidly dark roasted, low grown coffees. Drop the temperature to the low end of the espresso range. Dial in to the lungo end of the optimum crema range and dark stop the shot (you may be under 20 seconds when you do this, that's OK). These measures will not much reduce the ashiness, but will mask the problem with a little more brightness and crema. The real solution is to change blends.
Down, down, down went the temperature as we retried shot after shot... 198F... 197F... 196F... 195?!? At that temperature, the ashiness was nearly gone, the espresso the most pleasant of the series. But c'mon, we asked each other, this temperature readout can't be right, can it? A few minutes with the thermofilter confirmed a three degree offset between brewhead temperature and displayed temperature.
The lesson we learned tonight: Comfort in digital readouts is false comfort. Our tastebuds were yelling the answer and we ignored their calls because an LCD display said it wasn't so. "Fool me once, shame on you. Fool me twice, shame on me." :oops:
Postby annp on Thu Jul 06, 2006 9:35 pm
First, I'm glad you have the GS3 to play with, Dan.
I always appreciate your viewpoint because while you have all the graphs and gauges, you also approach stuff from a non professional perspective. You have solid data but you don't neglect usability impressions.
This machine puts out a beastly amount of heat. What do Italians have against insulation, at a minimum for the steam boiler?
Those of us who are left handed aren't too upset about the location of the steam arm...
I'm not sure about the brew controls as I'm used to a sexy little levetta. I'll miss the sexy little levetta, but you cannot have your cake and eat it too.
The heat thing sounds a little scary. So will we have an article pretty quickly after the GS3 reaches market called "How to Insulate the Boiler of your GS3?" We get hot enough up here in the woods of Georgia without more electronics in our home putting our AC in overtime.
Interesting situation with the temp gauge. I guess taste is the ultimate judge and I'll need to keep that in mind.
Just out of curiosity... What size (diameter) is that portafilter?
Ann
annp
PreviousNext
Return to Espresso Machines
