by darilon on Thu Nov 18, 2010 12:56 am
Barry: I agree that the probe by itself won't cause the sight tube bounce phenomenon, however, if the boiler were not filling properly, you would have mostly pressurized steam in the boiler and a balancing amount in the sight glass. If you were to tap the release on the sight glass as the OP explained, it would cause a bounce in the water level as pressure on the sight glass side was released and water force into it by the back pressure in the boiler. As the release seals back up, you get a bit of bouncing around from isostatic rebound. Still an easy thing to check, imho and well worth while.
