by shadowfax on Thu Feb 02, 2006 1:01 am
Today, I did my first descaling of Valentina. It seemed to go well, although it took about 3 boiler flushes to get the taste totally gone.
Anyway, now that I'm done, the machine's pump seems to be acting really odd. It sounds pretty normal when I free run it, but when I put the backflush disc on, it bogs down to the point of near silence. Not only that, but nearly nothing comes out of the overpressure valve... I don't really know what to think. I'd adjusted it not long ago (maybe less than a month) to the generally recommended ~2-2.5oz/30sec. So, if the OPV valve is suddenly off, that would be really weird, because I think it would have to go from being set at ~9 bar to 14 or 15 bar, whatever that pump caps off at.
Does a pump get "tired?" I know Dan's mentioned that these pumps are intended to be 30-sec on, 30-sec off, and I'd imagine that it ran for longer than that a few times filling the boiler up... I haven't broken my pump, do you suppose? Espresso performance is OK, I guess... it's acting physically pretty similarly, except the pump sounds a lot more labored and quiet during the pulls. but, roughly the same volume shots at the same grind and tamp pressure.
I can't comment much on taste, it's been sourish so far. the manometer started showing, after I descaled, that the pressurestat was cycling from 1.1-1.3 bars, where it had previously been cycling 0.9-1.2 or so... and I simply adjusted it down. The shots are a little acid-y so far.
Is such strange behavior typical of a descaling? Could my OPV be way off from the de-scaling? Any ideas?
