Common Espresso Machine O-rings & Copper Sealing Washers
AS-568 is the Aerospace Standard (AS) as well as the SAE (Society of Automotive Engineers) standard and is used for military and industrial manufacturing in North America.
See this website for a sizing chart on AS 568 O-rings:
http://www.oringsusa.com/html/o-rings.html See this website for a sizing chart on Italian specification O-rings:
http://mdmetric.com/or/corda1gb.htmLM Linea Check Valve(s)
AS-568 size: -012
McMaster-Carr P/N 9561K13
Material = NSF Certified EPDM
Vacuum Breaker Valve O-ring
OR 102 (Italian designation)
AS-568 size: -007
McMaster-Carr P/N 9396K12
Material = Silicone
Brew Solenoid Valve O-rings
OR 105 (Italian designation)
AS-568 size: -010
McMaster-Carr P/N P/N 9396K15
Material = Silicone
Ulka Pump Priming Valve
OR 2025 (Italian designation)
AS-568 size: -010
Material = Silicone
"Hardware store" o-rings will work fine for the priming valve but will not meet the temperature requirements of the others. See this website pdf for a nice sizing chart on sealing washers:
http://mdmetric.com/tech/DIN7603tdc.pdfIf anyone has another "common" o-ring, I will gladly do my best to add to the original list. As always, negative comments greatly appreciated.
