by michailza on Fri Feb 04, 2011 9:00 pm
Thank you for a suggestion. I think it was severe scale obstruction which caused the problem, as for now, solved by deep cleaning and repeated descaling/ backflushing. Hydraulics of the old 2nd-hand Oscar seems to work correct.
New problem: boiler cycle time.
Boiler is heating up well, there are no leaks. I do steam purge to release false pressure (no vacuum breaker on my model). After full heat up (even if I wait more then an hour) all seems to work correct, but boiler cycles very often. I did not measured it, but I would say, during idle time it turns on every minute or so for just several seconds. Is it normal? If I start to steam or brew water, boiler goes on almost immediately. Pressurestat is adjustable (made by CEME). Adjusting screw of the pressurestat works, I don't have instruments to measure temp/pressure (I will get what is needed soon), but as I can judge from steam power and brew water, boiler is getting to higher or lower pressure by adjusting the pressurestat, but regardless of pressure setting, boiler behavior is the same, very frequent cycles.
Questions:
1. Is that a pressurestat failure?
2. Can it be caused by a thermostat, electric connections or something else?
3. If I would need to change pressurestat, should I go for Sirai, or CEME/Parker/Mater/other will be sufficient?
4. Is it possible to fit bigger pressurestat as Sirai or Parker on the Oscar boiler without taking the boiler out of the case/frame?
5. I can't find more precise instructions/photos how to upgrade the Oscar with vacuum breaker. Where to put it on the boiler? Please help!
Thanks to everybody, have a nice day fellow coffee lovers!
