by karl_a_hall on Tue Feb 01, 2011 1:33 pm
Hey Marc. In general when working on things that include pressure vessels, it is never a good idea to make extreme adjustments. Sure, the logic may go like this: A smart person designed this machine, a well designed machine wouldn't have an adjustment that could lead to it blowing up, therefore I can adjust this as far as it would go. But that isn't quite accurate, especially since you are not sure of the functionality of all of the other parts. The overpressure valve may not be perfectly functioning and can even have scale caught up in it (if the machine was stored on its side previously, etc) and may not work correctly, I have seen it.
The temp you are measuring, as HB mentioned, isn't accurate. The response time of the thermometer, the speed at which the water cools, etc. I just did the test on my machine, the brew water was 201 and I measured only 180ish out of 3 tests. Depending on your budget, get an eric thermocouple adator, or a scace and then measure. I can hardly believe that the espresso tasted good at anything below 180 btw. So I am gonna trust your palate and guess it wasn't 160. That being said, the pressure of the boiler doesn't really even relate to the temp of your brew water unless you keep all other things (warm up time, flush time, etc). You can hit 200 at .8 bar or 200 at 1.8 bar boiler pressure. All you have changed is the final steady state temp of your HX loop. Do you notice any "steamy" water coming out of the group head after you have let it warm up for about 40 minutes? Have you been letting it warm up for at least 40 min?
